jdm gauge cluster.
Old Oct 27, 2004 | 12:44 PM
MacGruber's Avatar
MaDe Of MoNeY
Default jdm gauge cluster.
I have a 88 crx with a b16 and p30ecu. I have a jdm gauge cluster. the speedo does not work. It stays on 42kph or somewhere around there. I need to know if any one would be willing to wire it up for me? or at least help me. There is three wires that come off the vss. power ground and signal. Power goes to any old 12v power. Ground is ground. And signal. Signal is to the ecu and to the gauge cluster. On the p30 ecu this is the pin out for the vss which is number 10. Now i wired into that spot. And I ran the signal wire from the vss to the number 10 pinout. I then ran that same wire to the yellow and reb b1 pinnout on the back of the gauge cluster. now it should work with the power connected to a 12v source and the ground grounded wright? nope. Tell me what Im doing wrong I have no clue.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Oct 27, 2004 | 05:37 PM
MacGruber's Avatar
MaDe Of MoNeY
Old Oct 27, 2004 | 07:21 PM
oldandbusted's Avatar
hmm mine is the same way but only guages on it that works is gas and temp good luck!
Old Oct 27, 2004 | 07:28 PM
MacGruber's Avatar
MaDe Of MoNeY
yea everything else Is straight just need to wire up the speedo.
Old Oct 28, 2004 | 05:38 AM
juiced2ndgenteg's Avatar
do you have a electronic vss? you would might need one for that jdm cluster. I have read some funky things about jdm clusters for ef's and ed's.
Old Oct 28, 2004 | 10:52 AM
MacGruber's Avatar
MaDe Of MoNeY
yea the vss is installed and ready to go I just need some one to help me wire up those last 3 damn wires.
Old Oct 28, 2004 | 06:37 PM
MacGruber's Avatar
MaDe Of MoNeY
Old Oct 29, 2004 | 05:48 PM
lsrex212's Avatar
try grounding it somewhere else...i have a gsr cluster in my 91 crx and all is well for me. i grounded it out right on the shock tower...just make sure its a good clean connection...also, try to find a vss check list or something like that...you should be able to test the reading coming from it...i just dont know how...
Old Oct 29, 2004 | 06:17 PM
MacGruber's Avatar
MaDe Of MoNeY
I just found out that there is a wire comming into the cluster and a wire leaving the cluster for the vss I know the wire comming in but I dont know where the wire is for it to come out. Im just going to screw around with it tomorrow and hope I dont short it out.
Old Oct 30, 2004 | 09:37 AM
MacGruber's Avatar
MaDe Of MoNeY
god damn why is it this hard. Still cant figure this crap out.
