jdm gauge cluster.
Old Oct 30, 2004 | 01:49 PM
lsrex212's Avatar
the way my cluster is wired-
power-12v power
ground-shock tower
signal....run directly to the wire coming out of the cluster for vss...try that and see what happens
Old Oct 30, 2004 | 02:28 PM
Gotin's Avatar
Sayien
try pulling the cluster appart and ptting the jdm tach and speedo in the usdm cluster. the only downfall is that you will have to "break" the seal of the plastic in front.
-B.J.F-
Old Oct 30, 2004 | 02:57 PM
MacGruber's Avatar
MaDe Of MoNeY
the size of the jdm tach and speedo doesnt match the usdm ones.
Ive already tried that. when I rub the signal wire together the speedo jumpes but doesnt go back down to zero. and when I start the car it doesnt do anything. Could it be the vss? how would I check to see if its bad? thanks
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Oct 30, 2004 | 07:31 PM
lsrex212's Avatar
try to get a hold of a service manual for a newer integra or civic...maybe the vss is the same or similar...the service manual may have a procedure for testing the ohms/voltage/reading...whatever the hell you call the signal...either that or try to get another vss to use as a test dummy....btw, where are you located? ill pm you if i can find anything tomorrow
Old Oct 31, 2004 | 04:36 AM
MacGruber's Avatar
MaDe Of MoNeY
hillsborough. I have a guy that has a single cam vss Im going to see if he'll give it to me to try.
Old Nov 1, 2004 | 10:47 AM
MacGruber's Avatar
MaDe Of MoNeY
Old Nov 1, 2004 | 06:21 PM
  #17 (permalink)
R91Si's Avatar
i have a jdm cluster in my 91 hatch and i got everything to work...
Old Nov 2, 2004 | 02:24 AM
  #18 (permalink)
MacGruber's Avatar
MaDe Of MoNeY
do you mind taking a look at mine and tell me what im doing wrong thanks.
Old Nov 2, 2004 | 04:19 AM
  #19 (permalink)
Janky99's Avatar
Honda Guru
My electronic Vss wiring, 2 wires are into the gauge cluster, power, and signal, my vss wouldnt work without both the wires being in the cluster, so even if I hooked the one up to the signal on the cluster and the other one just to power, nothing, mike come down here one day and come take a look at mine. -Ben
Old Nov 2, 2004 | 06:14 PM
  #20 (permalink)
MacGruber's Avatar
MaDe Of MoNeY
cool as soon as I get a day off Ill give you a call and head down there. thanks
