decoding the precison sc61...
Old Oct 24, 2004 | 05:12 AM
boostedb16a3's Avatar
Equal Opportunity Hater
Default decoding the precison sc61...
can anyone here decode the etching on precision turbos. this is an etching off an sc61: 6169E
here is a link to the pic:
http://pg.photos.yahoo.com/ph/ericle...40.jpg&.src=ph
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Originally Posted by JAVIELITO
limpio as fukk
Old Oct 24, 2004 | 05:33 AM
Alpha's Avatar
The 6169E indicates what CHRA is used.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Oct 24, 2004 | 06:50 AM
do you think you could elaborate or at least break down that acronym?
limpio as fukk
Old Oct 24, 2004 | 07:03 AM
Alpha's Avatar
CHRA - center housing rotating assembly
The CHRA includes a complete turbocharger minus the compressor and turbine housings.
You have a Precision SC61 with an E compressor cover (.60 A/R) with a 69 trim (T31) turbine wheel. Precision only sells SC61's with a T350 76 trim turbine wheel now.
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Oct 24, 2004 | 08:31 AM
ok so this turbo will have a slight advantage of spool up on the newer sc61's w/ the .63 A/R, but will lack on the volume of air the turbo is capable of flowing. Thanks for your help Alpha.
-Joe
limpio as fukk
