Ls/Vtec MAJOR Timing issues
Old Oct 17, 2004 | 09:07 AM
Janky99's Avatar
Honda Guru
Originally posted by juiced2ndgenteg
why try to build an engine when you don't have a clue... pay someone to do it and stop wasting $$$$ on blown up engines. also are you sure your using the crank pulley mark that is by itself and not the one thats in the middle of three?
If you even knew how many single cams I've built, dont try to tell me I dont have a clue, keep that shit to yourself.. -Ben
Old Oct 17, 2004 | 09:11 AM
Janky99's Avatar
Honda Guru
Also, now that I'm looking at the lower crank gear, I see that it can only go on there one way because it has a locking key on one side, I dont know what it is, the little locking key is in the harmonic balancer. -Ben
Old Oct 17, 2004 | 11:24 AM
DirtyDave's Avatar
banned
someone go over there and help him !!!
Old Oct 17, 2004 | 04:42 PM
mtber's Avatar
Here is some baisic advice:
1. Buy a helms manual or get copies of the timing belt install pages from a local acura/honda dealer for a dohc vtec motor.
2. Remove the timing belt & crank pulley.
3. Line up your cam gears accordingly (up)
4. Line up your timing belt pulley on your crank with the mark on your oil pump according to the manuals instructions & Install the timing belt according to the manuals instructions....
5. Tension the belt... check tdc again & call it a day.
Old Oct 17, 2004 | 06:08 PM
NChatch's Avatar
i stepped on my weiner!
MTBER hit it on the head, pull the crank pulley off and look for the mark on the oil pump, there is a mark scribed on there that will line up witht the crank.
if all else fails, shit stick a damn screwdriver on top of the piston, bring up the crank till right before the screwdriver "floats" and should damn near be right on, thenk check the crank to be sure
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Oct 17, 2004 | 06:55 PM
Janky99's Avatar
Honda Guru
I'm gonna try to do that, I seen the mark on the crank gear but I didnt think to time it by that, I just always timed it by the pulley, its not like I dont know how to time a motor I've just never had a motor do this, Im gonna give it another shot by taking the puley off, I really appreciate everyones help. -Ben
Old Oct 17, 2004 | 07:39 PM
  #17 (permalink)
rangcrx's Avatar
engine building &best
its not going to start if that out of timing it wqill not have compression
i love AUTOZONE
Old Oct 18, 2004 | 03:27 AM
  #18 (permalink)
Drivermod03's Avatar
Ben did you fix it ? If not call me mabey I can help
Old Oct 18, 2004 | 08:42 AM
  #19 (permalink)
Jaso0on's Avatar
Is now ballin!
hes scared JFWY ben, jamie go help him so i wont be the only ls/vtec rex around........ i need someone to hang with me!!
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Oct 18, 2004 | 02:35 PM
  #20 (permalink)
Jaso0on's Avatar
Is now ballin!
w00t, it started.. just has a few bent valves in that pretty ol' 2001 gsr head.. lol
