Hitting limiter at 6,500
Old Oct 16, 2004 | 06:45 PM
  #21 (permalink)
CiViCBoY's Avatar
Lamer
Pretty much seems that way
What would the "pump motor" be?
Old Oct 16, 2004 | 11:27 PM
  #22 (permalink)
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
i had the sameee problem,and i couldnt figure out what it was.check your plugs & wires,and try the distributor,that was my problem.
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
Old Oct 17, 2004 | 07:28 AM
  #23 (permalink)
DirtyDave's Avatar
banned
do you have ABS 51 i thin is an ABS code pump motor.
Old Oct 17, 2004 | 04:07 PM
  #24 (permalink)
Derka's Avatar
TR Balla Donor Supreme
check your oil, if not check the dizzy
1998 crv daily beater
Old Oct 18, 2004 | 12:12 PM
  #25 (permalink)
djgspot's Avatar
my si does the same thing from time to time. i even took it to the dealership to see whats up. they said it was a loose wire somewhere and claimed they fixed it, but every now and again it still happens. i think its my vafc or ecu. just make sure you have enough oil because that'll do it to. you know v-tec engines burn oil
For sale: Garrett GT2554R-471171-3 (GT25R) Dual Ball Bearing Turbo w/Internal WG.
Old Oct 18, 2004 | 01:09 PM
  #26 (permalink)
Frankie Figs's Avatar
Too Much is ALMOST Enough
well the only time mine would do that is if the VTEC got unplugged but other than that it wouldnt do it. i looked at my code sheet and i dont have 11 or 51. i would check the codes again cuz those codes you posted are ABS codes. if it was throwing egr that would be a 12.
Old Oct 18, 2004 | 01:12 PM
  #27 (permalink)
is your car a EX or DX???
Old Oct 18, 2004 | 03:11 PM
  #28 (permalink)
CiViCBoY's Avatar
Lamer
it's a ex I checked them 3 times and it says the same thing
I always check the oil like every other day it don't seem to do that in 1st gear and the check light only comes on after driving for about 10 to 20 mins
Old Oct 18, 2004 | 05:38 PM
  #29 (permalink)
thats weird that it would flash the check engine light for abs codes wish i could help
Old Oct 18, 2004 | 06:08 PM
  #30 (permalink)
CiViCBoY's Avatar
Lamer
My SRS light is on also ??
when I jump the jumper to check the code what light should blank the check engine light or the srs light cause it's the srs light that blanks
