How high can I rev??
Old Sep 28, 2004 | 01:40 AM
Frankie Figs's Avatar
Too Much is ALMOST Enough
Default How high can I rev??
Is it safe to take a balanced LS crank to 9000+RPM?? I have a LS crank but I want to have a reliable motor thats not gonna die after a few passes.
Thanks, Frankie
Old Sep 28, 2004 | 04:50 AM
BERT-O's Avatar
yO!
If your oil pump part # reads #15100-p72-a01, your fine.
Anything beyond that your pushing it with oil starvation. With oil starvation, bearings don't get enough oil hence starts doing all kinds of weird stuff, like "boom" stuff.
The only cams that make power at 9000 RPM are Stage 3 Skunk2 or Toda Ds.
OEM cams or most of the 90% aftermarket cams don't make power beyond 8RPM, also depands on the header too!
Good luck, LMK if you need new OEM parts.
Hook up parts prices.
-Bert
Old Sep 28, 2004 | 04:51 AM
BERT-O's Avatar
yO!
btw, when I had Jun3s cams (best of 12.8s), it only peak at 8000 RPM, and shift at 8000 RPM since it drop after taht RPM. Same with OEM ITR cams, expect OEM had more midrange than the Jun3s.
Old Sep 28, 2004 | 06:13 AM
mtber's Avatar
You might want to take rod strength into consideration along with valvetrain etc
Old Sep 28, 2004 | 06:21 AM
99B16Si's Avatar
+1
Old Sep 28, 2004 | 08:47 AM
well this motor i am building is a ctr and im using the ls crank to stroke the motor and im using crower rods. the head has skunk 2 valvetrain and im saying 9000+ to make sure if i build power at like 8500 or so i know the crank will be good. also off topic but does anybody know where i can get a SC61 for a good price? thanks, frankie
Old Sep 28, 2004 | 11:18 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
You wont make power that high... Id say 8k-8500 is all youll need, but i see what your saying, better safe than sorry in case you miss a gear or something
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Sep 28, 2004 | 03:30 PM
yea so will the crank be safe to where ever i rev to if ut get it balanced?
Old Sep 28, 2004 | 07:38 PM
paulwelican's Avatar
evel knievel
rpm=ruin peoples motors.....8k is all u need frankie
