How high can I rev??
Old Sep 28, 2004 | 11:31 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
but i want to be sure that it will rev high so i have no worries
Old Sep 29, 2004 | 05:05 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
Originally posted by Cronic
With a large enough turbo, you can make power up there. Chris proved that.
I guess you do have a point there
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Sep 29, 2004 | 05:14 PM
DirtyDave's Avatar
banned
balnced or not a cast crank is only as strong as its weakest point. Even if its balanced it has the same tolerances (strength wise) than if its unbalanced only difference is how fast it breaks. LS Cranks are hefty but I wouldnt take one that high 8 at most build for 8500 and get a 2 step or rev limiter. I speak from experience when i say you dont need 9k rpm unless you like building engines ? my .2
Old Sep 29, 2004 | 05:33 PM
so 8000-8500 i should be good?? or should i just go with a gsr crank??
Old Sep 29, 2004 | 06:03 PM
60-1EK's Avatar
Engineer at the source
Ding ding. Stock ITR cams.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Sep 30, 2004 | 06:12 AM
Suspect's Avatar
Certified since '85
found out the hard way...............+1.
I would only rev my LS crank to about 82-8500 rpm
TR Hydroponics Abuser #36329
J a s o0o n: i need to get piss ass shit face fuck bag bitch ass drunk god damn
Old Sep 30, 2004 | 06:19 AM
  #17 (permalink)
mtber's Avatar
You can rev an ls crank & rods to 8.5k-9k with no problems.
People blow motors up with ls r/s ratios because they don't drive them properly & or don't build them properly in the 1st place.
The ls r/s ratio makes it a little more dangerous then lets say a GSR or ITR r/s ratio....
Personally, I would run ither setup depending on the availability of the components.
If you "have to be at 9k every day" spend a little money & go with a GSR/ITR r/s ratio
Old Sep 30, 2004 | 10:54 AM
  #18 (permalink)
ok thanks guy, I guess im gonna go with a gsr crank.
Old Sep 30, 2004 | 08:52 PM
  #19 (permalink)
nitrous-94integra's Avatar
what about valve, valve springs, and retainers i don't think it would be a good idea on stock ones to rev like that unless you like bending valves
Old Sep 30, 2004 | 09:05 PM
  #20 (permalink)
Retired Ricer...
if you read a few posts up, he has all skunk 2 valvetrain, although, ive seen some people rev the piss out off all stock ctr/itr valve train with no problems..........
