LS/vtec now................no damn vtec????
Old Sep 24, 2004 | 08:07 PM
NChatch's Avatar
i stepped on my weiner!
Default LS/vtec now................no damn vtec????
well i converted one of the crx's we have to an ls vtec set up, and i have done a few of them in the past but this is the first one that has given me problems.
B18a bottom end
B16 head
vafc
still OBD 0
i tried running the line to the back of the head.............no vtec
i tried removing the pressure switch and running it there............no vtec
the vafc shows output to the solinoid, and i hear it click but its like no oil wants to go past it, i changed pressure switches twice and now am boggled...........
could the machine shop have fucked up anything in my head when they had it????
i cannot think of anything else that could be wrong, is there any other variables i have not covered???????
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Sep 24, 2004 | 08:40 PM
mtber's Avatar
I pmed you back.
Sounds like cam cap oring
Old Sep 25, 2004 | 04:32 AM
NChatch's Avatar
yeah i saw that from an oldpost of yours on H-T, im gonna check it out.
he throws codes for
Knock sensor-doesnt have one
O2-needs a new one
vtec oil pressure switch-although i have changed it twice already
thanks john
owner/operator
Old Sep 25, 2004 | 06:40 AM
NChatch's Avatar
WELL I HOOKED UP A GAUGE AT THE TOP OF THE OIL LINE AND THERE IS ZERO OIL PRESSURE, WHAT THE HECK COULD THIS BE!!!!
i know shitty rod bearings will do this but what else, im gonna take all the fittings off and see if anything is clogged up in them
owner/operator
Old Sep 25, 2004 | 08:18 AM
mtber's Avatar
ohhh man...
I am sure you already know but:
1. Resolve oil pressure issue.
2. Resolve all codes
3. Vtec should work
Good luck man, sounds like your working with a nightmare motor.... I have been there.
Old Sep 25, 2004 | 10:18 AM
Jay's Avatar
Jay
Janky
shitty rod bearings will give you bad oil pressure????
Aim: o JankyJ o
http://jankycrew.com
Old Sep 25, 2004 | 11:47 AM
NChatch's Avatar
Problem solved thank god...............the fitting that goes into the back of the block, the 1/8th Bst had a normal hole on the outlet but about a pinhole on the inlet coming from the block so of course there was no pressure.......................im just glad i didnt buy the piece HE did, problem solved VTAK is back!
owner/operator
Old Sep 25, 2004 | 11:58 AM
mtber's Avatar
Wow, good to hear that.
