installed vafc...car now runs like $&*#
the throttle has negative and positive trigger make sure you have it set right or it can adjust the fuel correctly did you do the test at the begging it has you run a test to determine the sensors and responce of them all. The book has a setup for that or chewck the website it has detials on settingit up.
checked all wiring and all was correct. checked sensor readings and throttle setting, all read correct. I unpluged the vtec solenoid wires and the pressure signal wires and the put back the orignal wires to stock and the car runs right.
something with the vtec wires is making the car run like crap even at idle and wtih vtec not engaged.
maybe somehow the vafc was engaging the vtec at idle causing it to idle like shit????
92 240sx Vert-Drift car-CA Powa!
91 Civic Si-Minty Fresh-Boosted B20/Vtec
01 IS300-DD beater-2JZ no shit
found out that my vtec sol wire was in the wrong pin!! i changed it to the right pin and soldered ALL wires and the car now runs correctly but the VAFC isnt controlling my vtec change-over point.
I have the controller set at L-H 5800 and H-L 5700 and my vtec still engages at the stock 4800!!?! i dont get it ... any suggestions?
