turbo questions
Originally posted by 94lsTEG
A TT lets the car stay on after taking out the keys so the oil that is sitting in your lines/turbo goes back to the oil pan, and doesn't eat your lines away
Originally posted by 60-1EK
Haha....that is some funny stuff.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
If you want the turbo installed quickly then go to a "professional". if you want it installed correctly then learn how to do it yourself. the professional that does it doesn't give a shit about your car just the money. if he does something that breaks your car he is out money, but if you brake something you are out the money to fix it and you are with out a car, therefore you will be more careful than anyone else.
I have gone to "professionals" to have things installed because I wanted it done quick, well I just spent 2 days cleaning up the wiring mess that the "professionals" made with the wires. I am also still fixing the fuck ups that the "professional" did when I had my engine swapped. remember a professional is just someone who does something as a profession, so the guy at homedepot selling hotdogs is a professional hotdog vendor, the guy that cleans up the veiwing rooms at porn stores is a professional cum cleaner. the title professional doesn't mean jack.
learn to do it yourself, that way when your going down the interstate at 2am and your car craps out you'll have a good idea why and may even be able to fix it, instead of calling the "professional" that won't come out to help.
my 2cent
my 2cent
Guest
Posts: n/a
Originally posted by na200whp
are you saying that is not its intended use? oil and oil feed lines dont mix.
he stated that it runs the oil out of your turbo, and in fact it just runs oil threw the turbo to cool it down... so it still has oil in it at all times... there is never a time that it is run dry...
-Keith
Ahhhh the great misinformation that is the tee are.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Originally posted by `92CXhatch
p.s. oil does NOT eat oil lines... oil does not equal acid...
:o Wow, I have been owned and misinformed....I thought oil was totaly circulated through but eventualy all went back to the oil pan after a decent idle...learn something new every day!
Yeah if you just shut the car off with no turbo timer the turbo will still be spinning, but no more oil will be running through it causing the life of the turbo to be shortened.
