what you think about this setup
Old Sep 14, 2004 | 10:12 PM
2ndGenT3g's Avatar
For a Honda street engine that will run on pump gas, the maximum compression that should be run is in the low 11:1 range. The reason why Hondas can get away with this high compression ratio with modern unleaded fuel is mostly because of their superior combustion chamber shape and small bore diameters. Higher compression than this requires racing gas to avoid detonation. With cast pistons detonation should be avoided at all costs as they are more brittle than forged pistons.
||=|| ((O)) ||\\ || |D) //-\\
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
05 civic 4dr EX SE-SOLD!
08 Acura TSX_ 6mt
Old Sep 14, 2004 | 10:13 PM
2ndGenT3g's Avatar
oh im goin with jdm itr pistons with shot peened rods
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
08 Acura TSX_ 6mt
Old Sep 14, 2004 | 10:15 PM
mtber's Avatar
Dump the p30 itm for an aebs or itr manifold.
Check my sig for an example setup/numbers.
Old Sep 14, 2004 | 10:18 PM
mtber's Avatar
Any c/r under 12:1 more then fine for a n/a street application.
Ideal c/r is 11.5:1 for pump gas on a n/a street application.
Some people preffer using anything under 12.5:1 for street applications... to each is own.
Old Sep 15, 2004 | 10:33 AM
2ndGenT3g's Avatar
MY GOAL WITH THIS MOTOR IS TO JUST GET IT GOIN FOR NOW AND LATER IF IM NOT SATIFIED ILL DO STUFF TO PUT LOW BOOST ON IT OR JUST DO AS MUCH AS I CAN WITH IT TO GET DOWN THE 1320 FASTER AND THE STREET
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
08 Acura TSX_ 6mt
