Integra head gasket
Old Sep 10, 2004 | 11:13 PM
Punkinterviews's Avatar
Chavez Motorsports
Originally posted by DA92driver
why dont you go see collin at racing integration in tampa off busch blvd.hes pretty good with hondas and im sure he'll point you in the right direction..-Greg
Ummmm
He's good at what he does but you will never be able to afford him.
DA have you ever dealt with colin?
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Sep 10, 2004 | 11:15 PM
Chavez Motorsports
Originally posted by 2ndGenT3g
go with a spoon gasket my boy has one it will work a little expensive
Ummmm, the Spoon head gasket is 2 layers and RAISES compression......OEM is 3 layer.....
Stay OEM.
Kris
Chavez Motorsports
Old Sep 11, 2004 | 04:59 AM
Josh's Avatar
Dr. Doom
OEM.
Old Sep 11, 2004 | 09:27 AM
1slowcrx's Avatar
Does spoon have a headgasket for an LS block?
Stock LS compression is 9.2:1. You don't need to go any lower. An OEM headgasket is pretty good. 14psi doesn't mean anything, what turbo are you going to run?
The most overused word to describe an import: CLEAN. Every f****** car is so CLEAN.
Old Sep 11, 2004 | 12:41 PM
Josh's Avatar
Dr. Doom
please say t3/t4 in the 60 trim area.........
Old Sep 11, 2004 | 02:16 PM
94lsteg's Avatar
BOOST IS BETTER!
t3/t4 60-1 bb turbonetics, and don't be a dick keith...smartass..
Old Sep 11, 2004 | 02:28 PM
  #18 (permalink)
94lsteg's Avatar
BOOST IS BETTER!
Originally posted by `92CXhatch
right now you are doing nothing more than trying to do things that you have seen others do...
-Keith
...uhhhhh...wtf...I see others run turbos and now I'm doing it...whats so wrong with that? do you want me to do something that I have not seen before???? Cuz if thats the case, I am- i'm running a turbo on a teg with hubcaps, stock ride hight, and it's gonna be quite.........ass
Old Sep 11, 2004 | 02:32 PM
  #19 (permalink)
mtber's Avatar
This whole thread is pointless.....
Use a OEM 3 layer Acura Integra LS headgasket.
Cliff note:
I have heard of many people running 10+ psi on factory ls motors & not having problems. They did however run proper engine management & have proper tuning.
Old Sep 11, 2004 | 02:40 PM
  #20 (permalink)
Josh's Avatar
Dr. Doom
end of thread ^
