mustang 70MM throttle body?
ive heard that this is a direct bolt on to a b series intake manifold. is the tps the same as well? if so what year mostangs can i get it from?
tamparacing.com
It needs a little fabrication with it. It's not a direct bolt on. They do sell a custom plate you can use. The mustang TB and plate are ALOT cheaper than using the Honda one!
Kris
Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
Guest
Posts: n/a
Interesting, I'd never heard of this before.
It's a neet thing to add, with a tapered backplate. I'd like to see if you would gain any hp with this before the head swap. Afterwards, I would imagine you'd gain a couple ponies mid-top powerband.
Cory did that 2 years ago. It did work but nothing impressive. No point in having a TB bigger then your intake manifold. I know the JG is ported for a 65mm TB. Anything bigger is not worth it. I have a bone stock GSR TB on my car. I took off the 65 JG because of problems with TPS over a year ago and no difference. Granted this is a turbo application but 70mm is a waste. Try nitrous that will make power cheaply.
Originally posted by Mars_302
Indeed, unless you are making some serious power you will never need a 70mm. That is kinda big even for a mustang.
On my JR, I have the S pipe bored to a 65mm to match my JG TB. I was looking at the STR 68mm but it was useless since the S pipe was only dont to 65mm.
Kris
Chavez Motorsports
Chavez Motorsports
the inlet of the maifold i will be using is 65MM. if i was to get ahold of one of these i was planning on match porting the manifold to the throttlebody. that way there is perfect flow.
what modifications would i need to do tot he throttle body to get it working right? and what year RUSTang can i get it from?
tamparacing.com
