opinion on h22 in EK
Old Aug 26, 2004 | 07:07 PM
  #31 (permalink)
RyanCivic2000's Avatar
Fuck the DOHC
Originally posted by SuzukaSol
why turbo a d series when you can turbo an H series ..
Because a D Series is cheaper and has just as much potential.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Old Aug 26, 2004 | 07:18 PM
  #33 (permalink)
1BADP71's Avatar
E & I Certified
untill you can stroke a D16 to 2.2 L it does not have the same potential .
cheaper yes, but put 7 lbs on a D16 and your about even to the stock hp/tq of an H22. .. now add 7 lbs to the h22.... just to be fair ..
Old Aug 26, 2004 | 08:13 PM
  #34 (permalink)
Fuck the DOHC
Displacement isn't everything. I guarantee you the D16 I have has more potential than the 2.0 Ford Escort I used to have does.
Old Aug 27, 2004 | 05:13 AM
  #35 (permalink)
blurboEK's Avatar
proud father ;D
I was halfway done with a sohc buildup but decided to sell it all and go H22. honestly , if i were to build another sol to have fun with it would be a sohc turbo . they are underestimated . but thats only when this sol has to much power to drive daily. which isnt too far off.
wiring is not bad at all , i found it to be quite fun actually, but thats just me.
good luck . if you want to check out my swap send me a pm and I can let you check it out if i find a spare hour.
Wiring wouldn't be an issue when your putting an OBD-1 motor into an OBD-1 car. Now try that same swap with an OBD-2B car and OBD-1 motor
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
