Transmission and Warranty Question.
Old Aug 19, 2004 | 11:41 AM
jsimon9631's Avatar
Default Transmission and Warranty Question.
ok what do you guys think
there is a tech service bulletin for 02-03 acura RSXs for teh synchros as well as for teh cable of some sort
ok so im having that problem
ok now yes im Boosted but that is not why that is happening, its obviously from factory since there is a tech serv bull even for non boosted RSXs
i mean how could they prove to me that the turbo caused an already existing problem to occur?
isnt there a warranty law that says they have to prove to you that it was caused by that aftermarket part?
how could they since it happens even on non boosted ones?
discuss
Green Eyed Princess Lover
Mexican Jedi Pimp
NA is BEST
Old Aug 19, 2004 | 11:59 AM
jsimon9631's Avatar
Originally posted by 02CavyZ24
normally it states in your warranty that if the car is altered in any racing for it nulls and voids the warranty
but there is the Magnuson-Moss Warranty Act
that says that if they deny your warranty they have to technically write up how the aftermarket part CAUSED the problem. they cant just say that your warranty is void JUST because you have an aftermarket part.
http://www.sema.org/main/semaorghome.aspx?ID=8124
so i mean if its happening on cars that arent boosted or modified and there is actually a tech service bulletin out...how can they tell me that the turbo caused the issue in this case?
Mexican Jedi Pimp
NA is BEST
Old Aug 19, 2004 | 05:25 PM
98TRDCam's Avatar
iron lung
you could call around the acura dealerships and just ask (you dont have to go into specifics with them about your setup just a you were wondering kinda question)
Old Aug 19, 2004 | 06:08 PM
na200whp's Avatar
Powered by BOOST
i think it will be easyfor them to say that your turbo setup has put added strain on the transmission the factory didnt design it for. there district service mananger will get involved and either give in or will call you on the fact you wont take it to court. honda has very good lawyers.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Aug 19, 2004 | 06:30 PM
jsimon9631's Avatar
well the thing is that they already replaced the synchros once when i was stock
and when the clutch was installed the mechanic noticed there was an actual piece missing from the tranny and told me it would prob cause issues in the future
so in reality i could tell them that their lack of complete job on the last change of synchros could of caused this one too
who knows man its worth a shot obviously but if they dont do it than what can i say.
Mexican Jedi Pimp
NA is BEST
Old Aug 19, 2004 | 06:42 PM
Punkinterviews's Avatar
Chavez Motorsports
They will end up pulling your ECU and checking it and saying you shifted to fast or condition Good luck man, Take an AK-47 with you, they might do it then
Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
