i need help with 90 da integra
when i put the key in the ignition and try to start it, it wont start. there is a sensor or something by the ac blower that clicks, by its not getting power to the wire to the starter. is there anything else that would make it not get power.. like maybe the fusebox or something..
thanks
thanks
could be the ign sitch went bad mine did and i just made me a push button start from like a doorbell from home depot lol.
92 240sx Vert-Drift car-CA Powa!
91 Civic Si-Minty Fresh-Boosted B20/Vtec
01 IS300-DD beater-2JZ no shit
has the car been sitting?? the battery might be dead try jumping it..... if it wont hold a charge buy a new battery.
i had the same problem with my car when it sat for a couple days without me starting it. i would just get a clicking noise.
Replace your starter relay located near your heater core.
also one thing to check is there is one small wire that hooks to your starter its not making a good connection or not hooked on that will happen.
also the wire from your battery terminal should go strait to your starter and also split off to your fusebox.
make sure you have a good engine ground as well.
-Jay
-Jay
