Help car overheating!!!!
Old Aug 12, 2004 | 01:15 PM
primit's Avatar
Default Help car overheating!!!!
As title states changed the thermostat caues it was leaking.Thought mabey the head was warped but no smoke and no oil in the water or vice versa.Any input would be great thanks!!! Oh yea if you haul ass it cools down and the fan works
CREW MEMBER#2
d16a1 rides on all
rolling is not racing go from a dig or do not go at all
Old Aug 12, 2004 | 01:17 PM
fathead's Avatar
I'm aLL mOtOr I sWaRe ;)
low on coolant would be my guess..... my car did the same and it was cuz it was low on coolant... good luck with the fix
RIP Kevin "Slo_Si" You'll be missed by everyone who knew you my nigga.... I'll see you soon man...
Old Aug 12, 2004 | 10:23 PM
psycho's Avatar
when does it overheat? fans work? low coolant?
Old Aug 13, 2004 | 07:01 AM
Drivermod03's Avatar
Fan works aslong as the car sits and idles its fine as sone as you drive it the heat gauge goes straight to hot.
Old Aug 13, 2004 | 09:28 AM
Bill's Avatar
Livin' in Seattle
If the overheating started AFTER you replaced the thermostat AND you've got sufficient coolant, chances are you've got some air in the system. Happens all the time. Before stressing over possible problems, just pop the cap and let the car idle for a while. Keep an eye on the radiator neck for bubbles and on the thermostat reading for overheating. After fifteen or so minutes, put the cap back on and test it out.
Old Aug 13, 2004 | 10:47 AM
psycho's Avatar
from a personal experience, if the car overheats when driven and its fine when you are stopped, sounds like a bad circulation, wheather the water pump is bad or the radiator is clogged. Again, this is if fans work and the coolant is not low.
