asnyone good with fuel Pumps
Old Aug 10, 2004 | 10:58 AM
LZsBells's Avatar
Default anyone good with fuel Pumps <pics>
It's a 91 honda accord, I'm not sure if my fuel pump is still good or not, I think the problem might be in the wiring since I had to remove an aftermarket alarm in the process of fixing it. I pulled a fuel pump from a junkyard and connected it to the harness in the trunk. However, with the key in the On position and while attempting to start, I can't get the pump to activate. I've even tried connecting it directly to the battery and nothing happened but sparks. My questions are:
1. Is there a way to hotwire the fuel pump in my tank to test it?
2. Are there any other honda fuel pumps that work with my car?
3. Any tips on dropping my tank and installation of the pump
Thanks for your time
Only fool fight man with Z
Old Aug 10, 2004 | 06:31 PM
bobster's Avatar
connect a testlight to the power wire at the fuel pump. have someone turn on the ignition key. if you have power for about 2 seconds, and your pump doesnt run then you got a bad pump. its that simple
Old Aug 12, 2004 | 06:32 AM
LZsBells's Avatar
Default yup that got it
I pulled oput the multimeter and tested it the logical way instead of the haynes way. It's getting power so I'll have to drop the tank. Am I right in thinking that it's going to be a pain to replace it?
any tips?
Old Aug 12, 2004 | 06:48 AM
deez92's Avatar
mullet racing
drain the gas first if you have more than 1/2 a tank. you don't want that crap spilling all over you. and i would use a floor jack to lower the tank.
Great accomplishment only comes with great risk. I’ll accept the crippling, gut wrenching disappointment of risking all, and failing, but only by putting my whole heart and soul, my whole being into something, will I have the chance to walk among the stars.
Those who risk nothing, those who live their lives in fear, will never have that chance.
Failure is not a sin. It’s being too afraid to even try, that is a sin.
Old Aug 12, 2004 | 02:47 PM
LZsBells's Avatar
Actually, dropping the tank wasnt as bad as I thought, maybe it's because I prepared myself for the worse. However, after dropping the tank I discovered that the tank looked a bit rusty so Im thinking about replacing the tank as well.
This is just to my untrained eye, so I could be wrong. And now that I think about is the color of the gas was a orange color is gas suppost to be orange? I called around and for 100 bucks I can get the tank with pump and sending unit still attached.
Here are some pics if they work:
Here's a look inside the tank
Should gas be that color?
Here's where the tank was
