obd0-0bd1 dizzy
Old Jul 6, 2004 | 04:17 PM
kender's Avatar
gadget man
Default obd0-0bd1 dizzy
on a b16 engine will an obd1 dizzy work if the rest of the car is obd0. I will be converting to obd 1 in a month or 2 but I am getting the dizzy in a few days and I want to ops check it before it gets to far past the day I purchase it.
also when I replace the dizzy do I need to use a timing light or will I be ok if I mark the location of the rotor and line up the cam gear arrows ( so that they point to each other ).
U.S.S.A Crew Member #001
Old Jul 7, 2004 | 05:53 AM
kender's Avatar
gadget man
come on I know someone knows, please help
Old Jul 7, 2004 | 07:25 AM
60-1EK's Avatar
Engineer at the source
No they are not the same and no it will not work with the OBD0 ecu. As far as the timing goes, just spend the extra few minutes with a timing light and do it right. You can probably ball park it, but why bother.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jul 7, 2004 | 01:10 PM
kender's Avatar
gadget man
do you know if autozone or some place has a lone out timing light or are they cheap enough to just buy one?
Old Jul 7, 2004 | 01:22 PM
MacGruber's Avatar
MaDe Of MoNeY
different prices. i bought my craftsman for 69. If your in tampa Ill let you borrow it.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Jul 7, 2004 | 03:24 PM
kender's Avatar
gadget man
i'm in riverview, pm with an email address. It'll be a month or 2 before I have all the parts for the conversion and can put them on. thanks for the help
Old Jul 8, 2004 | 06:17 PM
94SentraSE-R's Avatar
why don't you get an obdo to obd1 adapter for the computer???
Sunny Day!
Old Jul 9, 2004 | 04:02 PM
kender's Avatar
gadget man
I plan on it and I have a p28 on the way and I am working on a deal for the conversion harness, but since I am going to be using hondata I would rather have hondata installed before I convert to obd1 so that my car is not without an ecu for a few days, and since it will be a month or 2 before I can do that I just wanted to check and see how I could ops check the dizzy to make sure it is good.
