EGR valve ..
Old Jul 9, 2004 | 01:07 PM
TSX24L's Avatar
Default EGR valve ..
My other crx has a code 12 that I have went thoughly and tested the vaccum on the egr vavle and it holds pressure. There is manifold vacuum. I checked the cvc vavle it holds a constant 8 like it suppose to.
Checked the 4 pin connector thats in the control box and it checks out and the egr does click. Any other things? The egr vavle is good, connectors to the ecu and wires are good. Iam stumped.
Old Jul 9, 2004 | 02:37 PM
TSX24L's Avatar
I know its only emissions bs but the car stalls when its cold sometimes. Its the only code on the ecu.
Old Jul 9, 2004 | 03:49 PM
Josh's Avatar
Dr. Doom
have you checked your 02 sensor yet? my teg did the same thing only when it was cold.
Old Jul 9, 2004 | 04:09 PM
TSX24L's Avatar
wouldn't it through a code though. I will check that out. Thanks.
Old Jul 9, 2004 | 04:17 PM
Josh's Avatar
Dr. Doom
mine didn't throw a code turns out it was a loose connection on the connector....it's worth checking, it's free.
