my car is loading up on fuel.....
Old Jun 14, 2004 | 09:15 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
Default my car is loading up on fuel.....
sat afternoon i decided to take some weight out my crx. (my 2 12's) that night went out to race and it was rather a bit cooler than normal. but my car was loading up on gas really bad. id be at a light and idleing fine but when i started to accel. it would bog like crazy and i would have to rev to about 5 grand to clear it out then it would work fine. if im rolling at a staged speed it would do it as well. any ideas on why this is all of a sudden happening?
tamparacing.com
Old Jun 14, 2004 | 09:30 AM
aaron1017's Avatar
is not Rotarded anymore!
Wow, my car is starting to do the same kinda that at the moment. I find if I let off the gas all the way and accelerate again, it revs alright.
Here is my thread... do high-jacking intended man.
https://www.tamparacing.com/forums/s...hreadid=160777
LS1/T56 Heads Cam 1994 FD
Old Jun 14, 2004 | 02:38 PM
CamaroJoe's Avatar
Landscape Engineer
Are you sure its bogging down because of too much fuel? Too little fuel will do the same thing. The first thing that came to my mind was that your throttle position sensor(TPS) might be sticking. The TPS is one of the most important sensors when it comes to fuel management and if it is sticking and thinks you are at low throttle, it will only send minimal fuel thus making your car bog down. Anything else I can think of would probably make your car run worse at idle and then run better as you increase RPMs, but here they are: bad air flow sensor, oxygen sensor, or spark distribution(plugs, wires, distribution unit, or any combo of those)
-Joe
Old Jun 14, 2004 | 02:45 PM
aj187's Avatar
FORE:exalt
yea sounds like the wires.. have you changed them yet?? i have had that happen to me with 2 cars.. check it out..
[url]
69 Buick Skylark - Brokeded
91 CRX hf (zc dohc swapped) - wrecked/fixed-wrecked/fixed-wrecked-sold
91 Civic hatch (stock) - Sold
91 CRX hf (ls swapped) - Traded
90 Civic Hatch (mini me) - Sold
91 CRX si (zc dohc swapped) - Brokeded
02 Dodge Ram - gave to repo man
06 gsxr 600 - Wrecked
95 cbr f3 (stunta) - Sold
96 Integra ls - Sold
94 Integra ls - Sold
02 Dodge Ram - Daily
Old Jun 14, 2004 | 02:46 PM
aj187's Avatar
FORE:exalt
yea sounds like the wires.. have you changed them yet? i had this happened to two of my cars before.. that was my problem..check them.
[url]
Old Jun 17, 2004 | 08:31 AM
brandoncm4's Avatar
dude its the spark plugs
Old Jun 17, 2004 | 04:17 PM
Vtec4theChildren's Avatar
take the plugs out and inspect them
