Custom Intake/Ice box
Old Jun 17, 2004 | 09:04 AM
smoke3's Avatar
Its a secret
Default Custom Intake/Ice box
I was plannin on redoing my intake, i am gonna make a icebox intake usint 2.5 or 3 in piping from the throttle body to the front bumber.
there are a few of these on honda tech that dont use filters or they use small mesh gauze in the piping will this be enough to run an intake like this with out a filter.
What about individual throttle bodies are those safe to run without filters etc
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
Old Jun 17, 2004 | 10:22 AM
Evangelion's Avatar
Good luck, but you'll get alittle more power out of an Iceman style, because it's made of plastic which doesn't soak up heat as much as aluminium. So I recommend making yours out of the same material, even PVC if materials are short.
Old Jun 17, 2004 | 10:58 AM
King_Of_Spades's Avatar
Over The Hill!!!
If your gonna make your own PVC works good because it doesnt absorb the heat as bad as aluminum. Although I would seriously suggest an purchasing an Air Bypass Valve to avoid water being sucked up into your intake because the filter is all down in your bumper/fender area.
Originally posted by Scott "Cars on nitrous are like old men on Viagra, Once the bottle is empty, their USELESS! "
AIM: KnEeDrAg129
Old Jun 17, 2004 | 01:42 PM
smoke3's Avatar
Its a secret
ok u guys are kinda missing the point i was askin about.
is it ok to run a no filter intake or use a thin gauze materail
(not my car)
(not my car)
u guys get the idea
so far im thinkin about alumi piping sprayed with engine enamel or i might for the pvc but that might be a bit heavy.
The Myspace Page
made.
- Its Game Time -
Old Jun 17, 2004 | 02:10 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
If you plan on driving your car on the street for any period of time you MUST have a filter.... there are filters you can buy specifically for your application that let the ram that you posted flow through them..... Check out www.weapon-r.com ....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jun 17, 2004 | 05:07 PM
Over The Hill!!!
yes you can do that without using a filter its not really reccomended but you can. I still would suggest the bypass gimmick to keep you from the ever so possible hydro-lock!
AIM: KnEeDrAg129
