running lean
Old Jun 9, 2004 | 07:04 AM
fl_hmong_racer's Avatar
Default running lean
i just came back from doing a base line run.i have a dual exhaust on my car and when we did the run, the O2 senor was only inserted in one of the exhaust.after the runs on the dyno. we saw that i might b running lean.(14/1 ratio). but the fact that i have 2 exhaust comes in play. so wat do u guys think, running lean or not?
IF YOU GOT A BROKEN LAPTOP YOU NEED FIX LET ME KNOW!!!!!!!!! I CAN FIX YOUR LAPTOP FOR A GOOD PRICE SO PM MEEEEE!!!!!!!!!!!!!
Old Jun 9, 2004 | 03:11 PM
smoke3's Avatar
Its a secret
i am not expert here but y couldnt u put the o2 sensor before the exhaust piping splits up. ??
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
Old Jun 9, 2004 | 03:15 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Pull your plugs and look at them, i believe if they're white you're running lean.
Old Jun 9, 2004 | 04:46 PM
CamaroJoe's Avatar
Landscape Engineer
He probably isn't splitting his exhaust. Its probably 2 different pipes the whole way. I always thought that 14-1 was pretty much what it was supposed to be. Maybe I'm thinking 17-1. Anways, just get it tuned using 1 O2 sensor and you'll probably correct your problem.
-Joe
Old Jun 9, 2004 | 05:51 PM
i can;t put the O2 sensor b4 because there is no space for me to gt in.its one exhaust splitting into 2. so if the plugs are black then the car is fine? thanx.
Old Jun 9, 2004 | 07:43 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
disconnect the exhaust and run the o2 sensor right off the downpipe if this is the turbod hatch were talkin about.. youll pick up a couple more ponies like that and get a more accurate a/f reading....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jun 10, 2004 | 03:34 AM
Retired Ricer...
Originally posted by Cronic
14:1 is lean for a turbo motor. Not N/A.
Some older EG's run as high as 18:1 at idle.
Econo boxes RULE!
Basicly, no you're not running lean.
I believe the car he's talking about is boosted....
