Ignition output signal? Help
Old Jun 8, 2004 | 12:23 PM
Janky99's Avatar
Honda Guru
Default Ignition output signal? Help
Hey I have a 91 crx Hf that was bought as a shell, it's throwing code 15 Ignition output signal, Ive tried 2 diff dizzys and 2 ecu's and still the same thing, no spark. If someone knows what could be the problem with it or what pin it is in the ecu.. so maybe I could wire it direct, thanks. -Ben
Old Jun 8, 2004 | 01:53 PM
NChatch's Avatar
i stepped on my weiner!
what motor is in it, it may have one of the 3 white wires in the distributor plug swapped in the wrong spot, depending on what motor was or is in it now, also depending onthe year
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jun 8, 2004 | 03:25 PM
Janky99's Avatar
Honda Guru
its a 91 crx with a d16a6 in it... -Ben
Old Jun 8, 2004 | 08:41 PM
U13SER's Avatar
Wire Your Dist Power Wire Up To A Switch And See If It Starts! It Will! Your Dist Isn't Getting Any Power!
Old Jun 9, 2004 | 09:12 AM
Janky99's Avatar
Honda Guru
what wire is the power? the blue wire on the 2 wire plugs? Thanks for the help. -Ben
Old Jun 9, 2004 | 03:21 PM
Janky99's Avatar
Honda Guru
I've tried hotwiring it, giving it direct power and still i cant get it to spark, still throwing code 15.. I cant figure it out.. -Ben
Old Jun 11, 2004 | 04:11 AM
Janky99's Avatar
Honda Guru
we got it cranked over but it wont stay running throwing codes 4 ( crank angle sensor) and 16 (fuel injector)
Old Jun 11, 2004 | 05:43 AM
aj187's Avatar
FORE:exalt
me and you are in the same boat man.. im throwing that same shit... i have the zc (similar to the d16) but yea mine stoped running.. so i bypassed (hotwire) the starter... get a positive wire and put it to the two connectors on the starter.. it should start up then.. this is how i have been starting mine up.. i have replaced the dizzy too.. cant figure it out yet.. but i will be tomorrow when i get some time.. so if i figure it out ill let you know..
[url]
69 Buick Skylark - Brokeded
91 CRX hf (zc dohc swapped) - wrecked/fixed-wrecked/fixed-wrecked-sold
91 Civic hatch (stock) - Sold
91 CRX hf (ls swapped) - Traded
90 Civic Hatch (mini me) - Sold
91 CRX si (zc dohc swapped) - Brokeded
02 Dodge Ram - gave to repo man
06 gsxr 600 - Wrecked
95 cbr f3 (stunta) - Sold
96 Integra ls - Sold
94 Integra ls - Sold
02 Dodge Ram - Daily
Old Jun 11, 2004 | 12:33 PM
dropcivic's Avatar
Redneck Proud
sounds like an ignitior. When my hatch threw a code 15, it was the dizzy, ignitior and ign. coil.
Honda certified Tech
Southern Pride not racism
Old Jun 11, 2004 | 05:37 PM
j0shth3j3w's Avatar
Everything is for trade.
fixed
Just text me.... 813-785-5222
