Ignition output signal? Help
Old Jun 11, 2004 | 10:57 PM
Janky99's Avatar
Honda Guru
I owned that car, this is how for future refrence.. Ignition output signal: checked if any of the white wires was putting out the 10 volts.. If at least one is putting it out, then run a wire from the 10 volts to the ecu and twist the 2 pins together (B17+B15) and that took care of the ignition output and gave it spark. -Ben
