Vtec Engagement Problem
Old Jun 7, 2004 | 08:09 AM
SEEKERone's Avatar
Trialed for Treason
i know this may sound funny but check the ground wire that bolts to the thermostat housing...i have had many problems caused by that thing being just a little loose
Liar, you couldn't cut me deeper with a knife if you tried
Old Jun 7, 2004 | 06:54 PM
CARNAG3's Avatar
ROTM March 2013
Just remebered that I have a damaged #4 injector. The plastic tip of the injector that sprays into the manifold is broken off so its not spraying correctly.
Could this cause the the car to studder during vtec?
Also im missing my knock sensor. Is the KS directly related to the vtec engagement?
help me out.
Old Jun 8, 2004 | 06:17 AM
Vtec4theChildren's Avatar
thats a lot of codes to be throwing
1 o2
2 o2
9 cyp
21 vtec silenoid
22 vtec oil pressure switch
has it always thrown those codes?
having a broken injector tip is not good either the spray pattern for that cylinder wil not be very good and the fuel may not atomize correctly resulting in poor combustion.
if you bring it up to Secret Services ill take a look at it for you
Old Jun 8, 2004 | 02:28 PM
CARNAG3's Avatar
ROTM March 2013
When should i bring it up there. would saturday afternoon be good?
and if anyone has a spare knock sensor for sale i need one ASAP!
Old Jun 8, 2004 | 05:54 PM
what ecu are you running that you need to run a knock sensor?
i dunno if well be there saturday afternoon
call first
Old Jun 8, 2004 | 06:34 PM
CARNAG3's Avatar
ROTM March 2013
obd-0 Pr3 ecu.
just got a new set of injectors, will replace them tomorow and see if it fixes the studdering during vtec
Old Jun 8, 2004 | 07:59 PM
  #17 (permalink)
pr3 doesnt use a knock sensor i thought
Old Jun 8, 2004 | 08:29 PM
  #18 (permalink)
U13SER's Avatar
Sounds like a lack of fuel Problem!
Old Jun 9, 2004 | 07:30 PM
  #19 (permalink)
CARNAG3's Avatar
ROTM March 2013
replaced the broken injector , still same problem.
Old Jun 10, 2004 | 05:59 AM
  #20 (permalink)
1fasthatch's Avatar
Traction Problems
+1
