Stange fuel problem.....
I'm looking under my hood when my car is running, mind you this is at idle, and my guage is pegged at 45psi @ IDLE!!!!! worked the throttle from under the hood and gave it a quick rev, stayed at 45psi, when i turn the car off, it goes down to zero. checked everything fuel related, return, FPR, filter...yada yada yada. my guess is it's just the guage, cause i put the stock regulator back on and it was still pegged at 45psi. any clue?
or if nothing else rewire the shiznits
hater's will hate no matter what so fuck em, also any car thats not an import fuck you 2......kinda contridicting huh?well if you think so fuck you too......(boost stage 2)
vaccum leak... been there done that... where is your car idling???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Originally posted by JOHNNIE
OR IF NOTHING ELSE REWIRE THE SHIZNITS
leak..............check all the vacume lines for any cuts or holes or maybe even came off but i had a small hole in mine before and it did the same thing
