VSS nightmare
Old May 20, 2004 | 06:50 PM
j0shth3j3w's Avatar
Everything is for trade.
Default VSS nightmare
Ok I am throwing a VSS code 17 my crx is converted to obd1 Neal did the wiring and we checked it and the signal is good. I replaced the cluster and the speedo cable it is new from Honda.
does anyone have any idea what else may be causeing this? I am trying to get it fixed by tomorrow.
Just text me.... 813-785-5222
Old May 20, 2004 | 06:51 PM
mtber's Avatar
Troubleshoot the system according to the Helms manual using a voltmeter. This will diagnose the issue for you.
Old May 20, 2004 | 06:58 PM
j0shth3j3w's Avatar
ok there is only one wire which was already tested so I am wondering if it is mechanical. But I think the only things envolved in the process are the cluster wired to the ecu, the speedo cable and the part that is attached to the tranny whatever that is called.
Old May 20, 2004 | 08:44 PM
crix's Avatar
:mugen member:
VSS-BLACK/YELLOW Power
BLACK- ground
blue/white-speed signal
LMK IF U need help ?
Old May 21, 2004 | 01:10 AM
j0shth3j3w's Avatar
I need help....
Old May 21, 2004 | 05:47 AM
j0shth3j3w's Avatar
F/O kieth.....
Old May 21, 2004 | 09:58 AM
Janky99's Avatar
Honda Guru
Hey crix, I think your reffering to the electric VSS, Josh has still got the stock cable driven vss in his crx. -Ben
