spun a rod bearing?
when you get into the gas it ticks been told it could be a rod bearing and been told its an exhaust leak at steady speed it doesnt tick or when going under 15mph but when you rev it will tick any help?
bearings have a very deep sound when they go bad. the best way to hear it is to be under your car, under the block's crank case. have someone rev the engine for you while you are under there.
DO NOT DO THIS!!! THIS IS WRONG!!! AND YOU COULD GET HURT VERY BADLY DOING THIS!!!
-Keith
-Keith
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Guest
Posts: n/a
-Keith
A rod bearing doesn't always knock from the moment you turn your car on it could knock wright when you turn it on at a high rpm or even like 3500 rpms not all bearings go out the exact same way and vito a valve is gonna make a knock noise crazy If your hearing a knock noise stop driving your car because your gonna cause a problem that cant be fixed like through a rod out your block my friend just did the other night it wasn't nothing nice but his happened within 15 min the motor started knocking 15 min later he was covering up a big ass oil spill in the middle of the road
I'll fuck you and all your fish eating lesbian friends in front of your fucking mothers your gonna die bitch im comming out the booth
so your saying a spun rod bearing ticks like a valve out of adjustment your a dumb ass
