Will ITR pistons fit in a b20
Old Apr 26, 2004 | 12:22 AM
Drivermod03's Avatar
Default Will ITR pistons fit in a b20
Will ITR pistons fit in a b20 block.
Old Apr 26, 2004 | 12:23 AM
Miles's Avatar
It's a wooden pickle.
no
Old Apr 26, 2004 | 12:30 AM
RONIN's Avatar
Tetris on a stick
sure but you'll need some massive rings... hell no
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Apr 26, 2004 | 12:42 AM
Just a simple no works good thanks for the info though.
Old Apr 26, 2004 | 04:28 AM
NChatch's Avatar
i stepped on my weiner!
B20s are 84mm and B18s start off at 81mm, just different strokes, that is why CTR pistons fit in B16s and B18s
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 26, 2004 | 11:57 AM
j0shth3j3w's Avatar
Everything is for trade.
they will if you re-sleeve it.
Just text me.... 813-785-5222
Old Apr 26, 2004 | 12:15 PM
Pookie Bear's Avatar
Lets Hug It Out Bitch
i thought b20's were 84.5
Chris...
aim- topendchris
kissxthexskys: what comes after 2299
kissxthexskys: 2300?
Top End Chris: seriously
Top End Chris: did u just ask that
Old Apr 26, 2004 | 06:54 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
Old Apr 27, 2004 | 02:37 AM
mtber's Avatar
For a b20 application you will need atleast 84mm pistons. Unfortunently there is no real good solution for a OEM style 84mm piston for a CRV/VTEC build.
So baisically you need forged rods & pistons such as Wiesco pistons / Eagle rods to achieve a good static C/R for a CRV/VTEC build.
I have heard of some companies such as topline that are considering making a replica Jdm ITR or JDM p30 piston in 84mm. I personally wouldnt waste my time researching into a non forged piston & rod setup to save a few bucks.
Old Apr 27, 2004 | 02:38 AM
mtber's Avatar
Why would you want to resleeve a 84mm block to 81mm and kill your displacement?
It would be the biggest waste of a 2.0L bottom end....
