spoon headgasket?
is it worth it to put a spoon headgasket in on a b16? what will the compresion be then? will i get a significant gain in torque and hp?its only 200 and i want to go all motor so what do you think?
thicker head gasket lower compression
i.e. with my cometic 12:6:1
thinner head gasket higher compression
i.e. with my stock 14:7:1
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
oh and in answer to the spoon question...the only difference you are going to get is the thickness of the gasket, the brand name is what you pay for.
...91 SMF SCCA
A spoon headgasket is not woth the money IMO.
Take your b16 head off, have it milled 10 thousands of an inch for $25 at clearwater cylinder head. Then buy an OEM b16 headgasket, remove the middle ply & install it.
Your compression ratio will increase & you will see some performance gains.
Honestly this is the cheap way to make power.
If you want to make real power, go with a built 1.8L bottom end or install CTR pistons/Cams & valve springs into your b16
Like the Mugen head gasket, the Spoon headgasket is laser welded and will raise your compression up slightly higher due to it's thinner design. The Spoon 2ply head gasket is measured at .45mm while the Mugen is measured at .47mm. Depending on your engines configuration, you can expect to raise compression levels by 0.3.
http://www.inlinefour.com/spoon2plyhea.html
