sohc turbo setup
Originally posted by XEventHorizonX
A D series turbo built right will be very very fast (easy 13s) and cheaper in the long run than a B series + turbo.
^^^^what he said. ive seen impressive numbers from the lowly D-series same as the money spent for a b16 installed.
Originally posted by Cronic
SRP's are off-the-shelf pistons... they're not usually custom, they do make them oversized...
HOWEVER, if you were to mic the pistons, you would see what Im refering too. I bought some, and they bounced around inside the cylinders. Most shops wont recommend them, because of said reason.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Originally posted by Vito_Corleone
So "very very fast" = 13s??? What planet are you from?
For a 1.6L SOHC four cylinder, that's damn fast, faster than most stock Mustangs and Camaros which push more power than a D16 turbo.
Originally posted by theebluecrx
And u have what...I'll just stop.
Originally posted by rschin
dont get ungry guys we suppost to talk about sohc engines and who got the best setup and trade knowledge ........thanx all
I dont know how many posts I have put this, but be sure that before you go cranking the boost up on your sohc, you better get the fuel managment/tuning to back it up. Basically, better run some Hondata. -Ben
