dizzy ?
ok i have a 91 hatch std and just droped a 90 si motor into it will the dizzy from the std work on the si because it bolted right up im just not sure if it will work let me know thanks...also if it wont work does anyone have one i could buy off of them
Sarasota Spoda
Sarasota Spoda
Is it the Std Dual Point? If its dual point then no, it wont work, youll need the dizzy off the Si or Hf, unless your leaving it dual point or unless you swapped wiring harness. Im not sure but i think it is DP. -Ben
