Dead End
Old Mar 26, 2004 | 08:10 PM
TRD_Tc's Avatar
Using The Force Of N/A
Default Dead End
I've hit a near dead end on my 99 Ls. So far I've added a DC Sports Header, AEM Underdrive Pulley Kit, Full exhaust piping to a CF Exhaust, Arospeed Coilovers, a B&M Short Shifter with Type R shift knob, and a AEM CAI. Now comes the problem.....What do I do now? I want to remain N/A (which means no Turbo, Supercharger, or Nitrous). So what's left for me to do while remaining N/A? I could use a little Imput.
Also, what would a Venom performance control module do for my car? Would it be worth the $300.00?
Old Mar 26, 2004 | 08:13 PM
Josh's Avatar
Dr. Doom
get a nice set of cams......mmmmmmmmmmmmm
Old Mar 26, 2004 | 08:25 PM
99B16Si's Avatar
either work the ls head or put a vtec head on it
Old Mar 26, 2004 | 08:26 PM
hspmick's Avatar
-Mick-
I agree
B18C1 build: Looking for 400+on pump gas. slowly coming along
Old Mar 26, 2004 | 08:44 PM
mtber's Avatar
Crane 0012 cams or crower stage 2 cams would work nice.
If you go ls/vtec you shouldnt just slap a head onto a stock ls block and expect good numbers...
You need:
High compression pistons such as JDM ITR pistons
Vtec oil/water pump & timing belt along
arp rod bolts for high reving insurance
new main & rod bearings
gsr/itr head studs
ls/vtec oil line kit
ls/vtec dowels & 1/8 npt plug for vtec head
the list goes on...
Old Mar 26, 2004 | 08:46 PM
mtber's Avatar
Here is a nice all motor ls
http://www.honda-tech.com/zerothread?id=784272
Old Mar 26, 2004 | 08:47 PM
Josh's Avatar
Dr. Doom
that is a sick setup, if i wasn't aquiring my dad's Si, i would do this setup!!!!!
Old Mar 26, 2004 | 08:50 PM
islandguy's Avatar
Chip your ecu
Vtec head
Toda cams
Have the head P&P
have the block bored
run 84.5mm high compression pistons
light weight flywheel
cam gears
dyno time
If modifying the bottom end isn't an option, you could get a Spoon/Mugen head gasket and raise the compression that way.
and the list goes on...
nine n a half years later my car has finally made it home
Old Mar 27, 2004 | 07:46 AM
TRD_Tc's Avatar
I'm trying to stay away from the V-Tec. I'm trying to make the most out of my little B18 without tearing everything appart. What else could I do?
Old Mar 27, 2004 | 07:52 AM
LS_ken-e's Avatar
A.D.D. for life
switch to obd 1, and get a chip.
fs- Kenji P06 ecu
then gets some cams.
LOOKING FOR 3rd Gen Integra windshield trim! HELP!!!!
not your typical honda driver...
AIM: kenracer18
