Jumper harness obd2a to obd1
Old Mar 25, 2004 | 02:43 PM
D.DIGGLER's Avatar
(Your car sucks)
Question Jumper harness obd2a to obd1
My integra has a check engine light on because my o2 sencer in my cat is reading wrong will the jumper harness fix this problem or will the obd1 ecu fix it or if neither fix it what will
Old Mar 25, 2004 | 03:07 PM
mtber's Avatar
The Jumper harness allows you to be able to USE the ecu in your vehicle.
What year is your car ?
What motor does it have in it ?
What ecu do you plan on using ?
Old Mar 25, 2004 | 03:30 PM
D.DIGGLER's Avatar
(Your car sucks)
98 integra ls b18b1 I have an ecu its out of a 94 integra ls
Old Mar 25, 2004 | 04:43 PM
60-1EK's Avatar
Engineer at the source
www.jkobdconversionharness.com
You can eliminate the secondary O2 when you go OBD1
JK
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 25, 2004 | 04:48 PM
D.DIGGLER's Avatar
(Your car sucks)
JK
Through the ecu or through the harness
Old Mar 25, 2004 | 07:41 PM
mtber's Avatar
The obd1 integra ls ecu only reads one 02 sensor.
The conversion harness does NOTHING but allow you to use a obd1 computer in your obd2 vehicle.
obd2a to obd1 is the conversion harness you need to run your obd1 ls computer.
Old Mar 25, 2004 | 08:35 PM
Punkinterviews's Avatar
Chavez Motorsports
Get the conversion harness to make your car OBD1 ECU capable and run the 94 LS ecu, engine light goes off and you smile!!!
I have a conversion harness if interested $100.
LMK
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Mar 26, 2004 | 03:25 PM
D.DIGGLER's Avatar
(Your car sucks)
could anyone tell me if this obd1 ecu will swop into 98 ls i thought i was getting a 94 ls ecu but that would be p75 i don't know what this one is i got it off of ebay every thing it says on it is E.L.Prototypes 92 to 95 ls integra 5speed engine b18a rev 9000 and the number on it is 37820-PO6-AO2-740-820622 AUI IPT
Old Mar 26, 2004 | 03:29 PM
D.DIGGLER's Avatar
(Your car sucks)
LMK
I'll probably get that off you in like a week if you still got it I'll pm you when I get the money thanks
