Tire Pressure ?
Old Mar 2, 2004 | 01:36 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
i believe you are correct on that but some tires differ.......
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Mar 2, 2004 | 02:59 PM
Josh's Avatar
Dr. Doom
just checking because the sticker inside on my driver side door jamb says the front should be inflated to 35 psi and the rear should be 33 psi. i wouldn't imagine it differing too much on other hondas.
Old Mar 2, 2004 | 03:31 PM
Retired Ricer...
stock honda/acura tires all run about the same but the aftermarkets differ alot....
Old Mar 2, 2004 | 03:40 PM
Josh's Avatar
Dr. Doom
this is true because my dad's Parada Spec 2's requires he run damn near 45psi up front (at least this is what he was told by tires plus), crazy shit.
Old Mar 2, 2004 | 05:16 PM
qitstrn's Avatar
Can you spot me 20 cars?
I run 15psi on street tires and 7 on slicks. you want sidewall flex. Some tires like falken azenis have very stiff sidewalls and you dont need much air. I would start at 20psi and go down. Fwd and Rwd are totally different when it comes to tires and pressure.
Old Mar 2, 2004 | 09:44 PM
integrakev78's Avatar
(Torqueless Wonder)
I don't see how u could get traction on a 13 inch rim with a stock tire period.You want traction you should get some weld 14x8s with a drag slick you wont spin those
