need help with crank pully bolt
Old Feb 25, 2004 | 01:47 PM
Team MWK's Avatar
Question need help with crank pully bolt
need to change water pump on my 91 teg and I tried everything to get the crank bolt out but it will not move .
Any ideas would be great.
Chris Millerleile
MidWest Kustomz
Old Feb 25, 2004 | 01:55 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
i had same problem on the same motor to put on a type r n1 pully so i took it to z fever because they have some strong ass air tools they did it in a second
Old Feb 25, 2004 | 01:56 PM
crix's Avatar
:mugen member:
if the car still works take it up to a shop & tell them to break it loose
with an impact gun...if it does not run then I know a few other tricks to get the bolt loose.......
Old Feb 25, 2004 | 02:00 PM
Janky99's Avatar
Honda Guru
Find the longest poll that will fit over a breaker bar, and have someone hold the flywheel so it doesnt move -Ben
Old Feb 25, 2004 | 02:05 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
agree with ben
Honda has a very inexpensive crank took to remove this bolt its like a big hex nut that fist inside the crank pully it wont damage the pully or crank...
FYI ben maybe the tranny is still connected to the engine ? just a thought.
If all else fails get a Big Freaking Air gun ! But the best bet is to get the Crank Wrench Snap has them as wellas some parts stores not that pricy and its a good tool to have.
Old Feb 25, 2004 | 06:30 PM
i needed a strong impact gun, we tried everything including heating,wd 40 nothing worked
Old Feb 25, 2004 | 06:48 PM
KJ's Avatar
KJ
bored at work
I use 700+ ft-lb air guns. Works every time
Old Feb 27, 2004 | 12:47 PM
Team MWK's Avatar
All ready tried turning the motor over did not work
Chris Millerleile
MidWest Kustomz
Old Feb 27, 2004 | 12:52 PM
+eleventybillion times !
Ingersaul Rand 3121 composite 800 Reversable ftlbs !
