need help with crank pully bolt
Old Feb 27, 2004 | 07:41 PM
SilentRacer640's Avatar
I had the same problem on my 88 hatch.
I just removed the starter and wedged a small crowbar to hold it in place.
then I took a huge pole and it pull loose real quick.
good luck
Old Feb 27, 2004 | 07:45 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
good luck
dont do that youll fuck up the teeth on the flywheel and then fuck up your starter ! *shacks head* IMPACT !!!! or get the honda tool and a big ass pry bar OR heres what we did once
get a block of wood about the level of the crank ! there is a lil slot in the shroud put a long ass extension on the crank so it sticks out about 1-2 feet clearing the fender put the wrench on the block of wood like a axis point and put a long ass freagiong pipe on the wrench and pull down youll get mad leverage from the block of wood ! but we had a 3 foot breaker bar too andmy fat ass jumping on it !
Old Feb 27, 2004 | 08:46 PM
mtber's Avatar
Honda makes a $100 tool that is a 52mm opening that sits in the crank pulley.
You use it to stop the crank pulley from moving while using a braker bar.
