DIFFERENCES in GSR and LS YS1
Old Feb 25, 2004 | 03:41 PM
j0shth3j3w's Avatar
Everything is for trade.
Originally posted by Sharpview
josh- thanx for the numbers . . . is it the higher the number the shorter the gear ratio ?
Yes thats right.
Ok 1slowcrx lets just think about it for a second:
a)the ys1 acura integra GSR 90-93 (b17a1) which is a cable tranny
b)the ys1 acura integra LS 92-up (b18a1) which is hydrolic tranny
So if the sticker is YS1 and the tranny is cable then its a GSR and if the sticker is YS1 and the tranny is hydrolic then its a LS. So the sticker would actually help tell what the tranny is hence thats what the hell I find out when I "go by the sticker" a little more than jack shit.
Josh
Just text me.... 813-785-5222
Old Feb 25, 2004 | 03:52 PM
91Crx but i heard vtec's Avatar
All Socoms CAMOPIMPIN
hey janky1 jsut so u know your answer "b)the ys1 acura integra LS 92-up (b18a1) which is hydrolic tranny "
you are wrong on that 92 93 they made 2 different cable ys1 trannys one for the gsr and one for the ls two different gear ratios
94 and up integras have hydrolic trannys not the older tegs
92 -93 = cable trannys doesnt matter ls or gsr
94and up = hydro trannys
DONT SLEEP's penis tastes soooooo good
Old Feb 25, 2004 | 04:56 PM
j0shth3j3w's Avatar
I stand corrected I knew that but was thinking Civic.
Josh
Old Feb 25, 2004 | 05:33 PM
KJ's Avatar
KJ
bored at work
no way to know without opening it up and counting teeth or by putting it in a known gear and turning it over by the input shaft and counting how many times the differential spins with respect to the the input shaft. To do this you have to do some math first.
Old Feb 25, 2004 | 06:01 PM
yeah might as well open it up cause that would suck trying to count that shit but its a good idea kj
Old Feb 27, 2004 | 02:14 AM
calloway 91si's Avatar
i went through the same thing but it was the other way around i bought a tranny that i thought was an ls but it was a gsr and it said ys1 as it does on both i consider myself lucky to get a deal like that but with a ys1 gsr at 3000rpm's in 5th gear you should be going exactly 60 mph
Old Feb 27, 2004 | 08:59 PM
  #17 (permalink)
1slowcrx's Avatar
I believe you have the ys1 (LS) tranny. If it's the GSR tranny, you should be at 3500rpm...the us tranny you're at 2895.
http://crx.honda-perf.org/math/index.html
Old Feb 28, 2004 | 09:23 AM
  #18 (permalink)
yeah i have a ys1 gsr and i am at 3500 at 60
Old Feb 29, 2004 | 01:55 AM
  #19 (permalink)
well so much for that idea
