Vtec Hook-Up
The VAFC can adjust the vtec, fuel, etc....The P28 ecu has the correct fuel and timing maps for that engine. Not to mention the correct method for engaging Vtec. To convert to OBD1...P28, you will need the Vtec distributor from that motor, a 4 wire O2 sensor, and my harness. It is a very simple install after that guided with detailed instructions.
Jason
Jason
150 shipped in the states. All brand new OEM pieces. Lifetime warranty. Check out www.Honda-tech.com and look for me under "Blown90hatcH". Also, Vapor has some of my harnesses at his shop as well. I think he has 2-1 harnesses in stock at this time.
the cntroller can run the vtec its a light blue wire but youll have incorrect fuel maps when you install a controller the ECM never sees the VTEC again so any ECM will work the controller solely controls VTEC functions its the VTM signal Lt Blue wire. C-speedracing explains how to install it hook it up and basicly follow thw APEXi directions its simple.
