help please!
i got a crx with zc swap and when i start up the car like in the morning when its very cold it stutters alot, and then when it warms up it drives better. When its warm the car will still do it but not as bad, it will do it if i floor maybe stutter 3 or 4 times. Sometimes not at all but it still feels like sumthin is wrong..Also when the car is just idling sumtimes it will just shut off...sparks are new wires are fine...WHAT COULD IT BE??
I'd start with a new fuel filter.it could be low fuel pressure. fuel pump may be losing pressure. Maf sensor or O2 sensor may be bad. Cat may be clogged - Fuel injectors may be dirty and clogged as well. Hesitation could be a lot of things.
Buy my skateboard: http://cm.ebay.com/cm/ck/1065-29322-2357-0?uid=&site=0&ver=EOISUA080805&lk=URL&item=7189554 921
Honda Tells U.S. Auto Makers to Try Harder (Reuters): U.S. auto makers will have to pull up their socks in the face of increasing inroads by Japanese competitors into the U.S. market, Honda Motor Co President Hiroyuki Yoshino said on Wednesday."They should try harder," Yoshino told reporters...
hehe, back again, stuttering,
check distrib cap/ rotor/and ignitor/coil, fuel filter, plugs gapped correctly?, vaccum leaks from hoses? intake mani? fuel injectors? you may want to do a comp test, or just have a leak down test preformed on it.
also check your wiring could be grounding somewhere(unless its heat shrinked)
Not to step on anyones toes but Hondas dont have MAFs....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
