car trouble, help me please
Old Feb 21, 2004 | 10:01 AM
StricKlyMT's Avatar
aka civicke96
Originally posted by 91IntegVtec
bought brand new 9.3 mm wires with NGK iridium 19's, dont get any better than that
it maybe just preferance but i love stock wires i would use your stock wires
Old Feb 21, 2004 | 10:08 AM
styles999's Avatar
Powered ByYo Mommas Mouth
I would guess Sticky valves, or incorrect timing, but over 90% of problems come down to Ignition components, such as Distrbutor, rotor, plugs, wires, timing........ does it back fire/studder through the intake mani?
you may want to check your ignition coil, my b16 did that for over 4 months (well something similar) and as soon as i replaced the ign coil from the b16 to the USDM civic SI coil it runs fine.
Old Feb 21, 2004 | 08:04 PM
91IntegVtec's Avatar
is the ignition coil inside the distributor assembly? if so then i shouldn't need it changed out b/c my dist. is brand new...and yes it backfires through the intake mani sometimes
Old Feb 22, 2004 | 06:17 AM
styles999's Avatar
im not sure on the Correct stock timing, but i would check your timimg.....if its fine then it could be valve clearances or sticking valves, in that case you would have to take the head off and get it decarbonized.....
since you said you replaced the plugs/wires i dont think your insulators for the plugs are faulty....did you gap them correctly?
your fuel injectors, intake mani could also have a vaccum leak....
and yeah, the coil is in the distrib assy.
Old Feb 22, 2004 | 09:50 AM
vertigo_16201's Avatar
put a volt meter on your map sensor to make sure its reading the correct voltage. My car did the exact same thing when the vac line to my map sensor burst.
Old Feb 22, 2004 | 10:18 AM
StricKlyMT's Avatar
aka civicke96
yes the ignition coil is inside the dist.
Old Feb 22, 2004 | 06:57 PM
  #17 (permalink)
inikoni's Avatar
Yonaka Hashiri-ma
does the car emit any white smoke from the exhaust ..is so it could be a cooling issue ..broken head gasket or you termostat ...thoise same kinda problems were happeneing to my friends 240. also you injectors could be misfiring possibly do to a bad lead...many things can be looked at hope something helps
UniversityCentralFlorida
Old Feb 22, 2004 | 06:59 PM
  #18 (permalink)
inikoni's Avatar
Yonaka Hashiri-ma
if this just started happening it could just be a bad tank of gas?
