Hondata question
yea I'm gonna go Hondata s200.
So first the conversion to OBD1 . . . does that really only consist of getting a GSR distributor and a OBD0 to OBD1 jumper harness and ECU (P72) right?. . . . . .
thanx Cronic
thanx Cronic
Guest
Posts: n/a
D3f1|\|473ly g0 0BD1. Zdy|\|3 15 |\|1c3, bu7 0bd 0 15 |\|07 v3|2y |23l14bl3. D157|21bu70|25 4|23 much b3773|2 1|\| 0bd1.
5h4|2pV13\^/, y0u |\|33d d157|21bu70|2, 4|\|d 4 4 \^/1|23 02 b351d35 7h3 h4|2|\|355.
C0|\|74c7 m3 \^/h3|\| y0u |\|33d H0|\|d474
60-1EK- will your OBD0 to OBD1 conversion harness work if I want to use a P72 ECU? you say you have P28s, which one is best for my application/ or does it really matter?
Cronic - thanx again . . .
Guest
Posts: n/a
[QU073][1]0|21g1|\|4lly p0573d by 5h4|2pv13\^/ [/1]
60-13K- \^/1ll y0u|2 0BD0 70 0BD1 c0|\|v3|2510|\| h4|2|\|355 \^/0|2k 1f 1 \^/4|\|7 70 u53 4 P72 3CU? y0u 54y y0u h4v3 P285, \^/h1ch 0|\|3 15 b357 f0|2 my 4ppl1c4710|\|/ 0|2 d035 17 |234lly m4773|2?
C|20|\|1c - 7h4|\|>< 4g41|\| . . . [/QU073]
H15 h4|2|\|355 \^/1ll \^/0|2k \^/17h 4|\|y 0bd1 3cu
Originally posted by Vapor
If you are not using the OEM GSR intake manifold, then any obd1 vtec ecu will work (except prelude). If you ARE, then P72
Sorry to jack the thread but...I thought you had to use a p72 to get the GSR manifold to open the butterfly gimmicks. And if he is how is he OBD0.
Sharpview what head/ECU are you using?
Did somebody bass tape you?
Its a stock longblock w/ stock intake mani . . . apparently the butterflies wont open with the obdO setup . .
The setup runs and drives fine just has alot of untapped potential and well . . . running in loop mode right now due to a knock sensor code and only having one O2 sensor (after reading up on Hondata's site looks like it is wired wrong, <2 wires into one> however its not throwing a code for it) O2 sensor that is . . . . .
The knock sensor is wired correctly and its a new sensor so i'm stumped. Maybe conversion to OBD1 will clear it up . .
With regard to the 4 wire O2: is this one O2 sensor that has 4 wires or 2 O2's with 2 wires each?
one o2 sensor with four wires.
Gracie Barra Clearwater
