codes 14/43
14 is iacv idle air control valve
43 is fuel system
I replaced the idle air and it still through's the code.
When I am driving with little gas it jerks the car like I just learned how to drive a stick it is bugging the heck out of me. Has anyone had this problem and what did you do to fix it?
Josh
43 is fuel system
Josh
i have the same problem, the idle air control valve on mine gave me a check light, so i took mine of and put a 97 instead of a 94, the car is running better then it did b4 but the light is still, do u guys think that it might b caused by the different yr?
IF YOU GOT A BROKEN LAPTOP YOU NEED FIX LET ME KNOW!!!!!!!!! I CAN FIX YOUR LAPTOP FOR A GOOD PRICE SO PM MEEEEE!!!!!!!!!!!!!
ok the codes are 10 IAT Sensor (Intake Air Temperature) and 14 IAC Valve (Idle Air Control) now and its 23 KS (Knock Sensor) sorry not 43 (fuel supply system) and I have replaced the fuel filter did nothing to help. The car at low throttle acts like I am just learning to drive a stick. I also tried unplugging both sensors and swithing them. I replaced the IAC.
Josh
Josh
Guest
Posts: n/a
ch3ck y0u|2 m41|\| g|20u|\|d 7h47 15 l0c473d 0|\| 7h3 7h3|2m05747 h0u51|\|g. D0 y0u 571ll h4v3 y0u|2 f457 1dl3 7h3|2m0 v4lv3? 17'5 l0c473d 0|\| 7h3 b0770m 0f 7h3 7B. 175 c0mm0|\| f0|2 7h3m 70 g0 b4d 4|\|d c4u53 155u35 l1k3 7h15. H0\^/ 15 y0u|2 1dl3? D0 y0u h4v3 4 fu3l p|2355u|23 g4ug3?
I had a problem like that and like john said check your grounds on the motor..Mine came of the tranny and i couldnt even get the car to go over 2k like janky1 said looked like i could not drive my car just kept sputering.. I would also check the seals under the valve cover on each spark plug..If one of those goes bad it will soak the spark plug with oil ,then when that cyl fires it burns the oil off..But it will do the samething your talking about will sputter at low rpms... Just trying to help out..leting you know my problems ive had..
actually the idle is fine . . . well except sometimes it lingers at 1500 RPMs then if you tap the gas it'll settle down to a normal idle. . . .
the problem is really that you have to either be on it (gas) hard or completely off of it. . . . . if you try and feather or hold the gas at a certain speed it starts bucking like you cant drive a stick.
i just talked to the kid that had the car before me and he said that it has always done that since the swap was installed
. . .hope that helps
