Slight hesitation
If things couldn't get any more weird, now i am having a problem with my teg hesitating when i put the gas to the floor shortly after starting the car up. this only happens when the car has just been started and warmed up. Atfer the car warms up, there is vitually no problem. My guess is the fuel filter, but should i be looking for anything else? all my 02's are fine, i really hope it's just the fuel filter. Any suggestions?
injectors ? what is done to the car ? i dont remember your car. If O2's look fine i cant really say fuel ! lackof fuel would show leanconditionor even if its sputtering itd show spikes or dips on reading ? Change the filter just to be sure ?
Originally posted by Punkinterviews
drive it easy till it warms up
Change the filter and run some fuel system cleaner through it... worked for me when my single cam did that.....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
yeah i need to do the same thing im running a little lean for some reason
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
try the filter and injector cleaner as above, solved the same issue for me too... if i was at part throttle driving down the raod, and would dip in the throttle a little more, it would bog really quick, then it would smoothe out again.
if that doesn't solve it then you might have a tps issue
Eat a live toad every morning, and that will be the worst thing to happen every day.
