many sohc questions
Old Feb 6, 2004 | 08:29 AM
evol_crx_si's Avatar
Aint Flakin
Default many sohc questions
well first, where is the best place to get my head ported for the buck?
what is the ave. price for a stripe/street port job?
Why would a sohc burn up 2 or 3 MAP sensors in less than 2 weeks?
If i'm running 11.5 to 12 compression, should i be able to run the car on pump gas and still get a good burn on the plugs or should i be using octane booster?
if i should be using booster which is the best i should be use?
thanks guys for the tips and help before hand
Old Feb 6, 2004 | 08:37 AM
1QWKCRX's Avatar
That CRX Guy
Not sure on the P&P work out in Tampa. There is no reason
to be frying out MAP sensors unless you've got a short
of some kind going on. Any water damage to your car?
What kind of motor are you running? SOHC VTEC? D16A?
That is a high comp ratio (I hope you are running N/A and
not planning on booting anytime soon!) I'm running 11:1
on my sohc VTEC running on 93 oct with no problems.
Just check the timing on your motor, use good gas, dyno and
do a wide band and see where yu are running (rich/lean)
and you should have no problems.
Good luck!
Florida CRX Meet 2011 http://www.facebook.com/pages/Florid...2354313?ref=ts
Old Feb 6, 2004 | 09:13 AM
chi town brat's Avatar
! Ne shab'rud'ni !
hi Ken ~ 1qwkcrx
i have a sohc vtec 12.6.1 compression ratio running on 93 octane due to advancing my timing.
do you have a fuel pressure reg and an adjustable timing gear?
