what axle . . ?
Old Feb 6, 2004 | 05:16 AM
Sharpview's Avatar
hyperbola
Default what axle . . ?
ive got an EF w/a b18c1 swap and have a cracked CV . . going to replace axles. . . . what axles are used in this swap? is it a early 90's teg?
Old Feb 6, 2004 | 05:45 AM
rangcrx's Avatar
engine building &best
no you need 94+ Gsr axles does not matter if abs/or automatic just tell them you need 95 acura 1.8 dohc Vtec axles
i love AUTOZONE
Old Feb 6, 2004 | 05:59 AM
Sharpview's Avatar
hyperbola
even if i have a LS cable tranny?
Old Feb 6, 2004 | 07:19 AM
99B16Si's Avatar
90-93 teg
Old Feb 6, 2004 | 09:43 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Originally posted by 99B16Si
90-93 teg
Old Feb 6, 2004 | 10:00 AM
Sharpview's Avatar
hyperbola
cool thanx guys . . for both sides right?
Old Feb 6, 2004 | 10:52 AM
rangcrx's Avatar
what the hell you talking about ok you go and buy a drivers side axle for your HALF SHAFT FROM A GSR and see if a 90-93 Cv axle will fit AND ALL 90-01 passanger side axles are the same so shut the hell up i no what im talking about
i love AUTOZONE
Old Feb 6, 2004 | 11:16 AM
Sharpview's Avatar
hyperbola
. . . .its an 1989 EF dont know if that makes any difference
i thought it was early 90's but wasnt sure . . . thanks again changing soon.
Old Feb 6, 2004 | 11:26 AM
rangcrx's Avatar
does not matter the wheel hubs are the same teeth,and almost the same width,but the passanger side axle you can get from any integra as for the drivers side unlike the top people that dont no to much your gsr motor as like the 99-00 si b16 it has a different halfshaft the half shaft is a small shaft that bolts to the block of your car so that you may make the cvaxle fit,and makes it more stable unlike have one 3 foot axle like Dseries...well your gsr motor has a MALE end on it unlike the 90-93 halfshaft that has a FEMALE so do the math if you buy a 90-93 cvaxle it will have a both male ends and will not fit into your 94+gsr halfshaft
i love AUTOZONE
