blown engine???
Old Jan 30, 2004 | 02:47 PM
defekt's Avatar
Default blown engine???
well i was leaving a toll booth on veterans expressway on the way home from work, i was gunning it pretty hard at 5500rpm in 2nd gear when i heard a KABOOM and the car shut off immediatly.. so i pulled over to the side and tried to start it up.. it wont crank over but it clicks tho.. my dad said it might be the timing? i just bought this car tuesday and put no more then 150 miles on it. it's a 91 civic lx with 98k
sucks tho too... i just bought octane booster, oil+fuel filters, oil, engine restorer, sparks plug today on my lunch break
anyone have an idea?
RIP my Brother Jason 5/26/1980 - 9/09/2011
Old Jan 30, 2004 | 05:10 PM
Josh's Avatar
Dr. Doom
Originally posted by Cronic
Check the timing belt, then do a compression test.
Old Jan 30, 2004 | 05:47 PM
specie's Avatar
check the timing belt, if that's not the problem, check your distributor.
Old Jan 30, 2004 | 07:25 PM
defekt's Avatar
ok thanks
Old Jan 31, 2004 | 05:32 AM
defekt's Avatar
ok well the timing belt rotted to hell and broke..
is this an interference engine?? how the hell do we put the timing belt on... looks like we gotta take a whole bunch of shit off to get to it..
Old Jan 31, 2004 | 05:47 AM
Punkinterviews's Avatar
Chavez Motorsports
You probably pushed your pistons into your valves......NEW MOTOR TIME!!!
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Jan 31, 2004 | 06:16 AM
99B16Si's Avatar
if it went boom something got fucked up. pull the spark plugs and if they looked fucked up your motor is too
Old Jan 31, 2004 | 06:35 AM
qitstrn's Avatar
Can you spot me 20 cars?
Thats sucks. Time for a honda.
