idle problems
Old Jan 29, 2004 | 05:17 PM
Kermit sol's Avatar
never shit a shooter
Default idle problems
ok i bought a aftermarket intake manifold for my d16z6 when i went to put it on i realized it was the wrong one, so i put my stock one back on and now my car idles around 2500 and every 3 or 4 sec it drops back down to about 1500. does anywhone know what that might be and what i would have to do to fix it.
thank you
wish i could hit 9k
Old Jan 29, 2004 | 05:31 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
did you put a new gasket on the t/b and intake manifold if not it will definatly do that
you need one from t/b to i/m and i/m to head
Old Jan 29, 2004 | 05:38 PM
Kermit sol's Avatar
i put a new one on from the intake manifold to the head, but the one from the throddle body wasnt broken so i left it on. should i change the one on the throddle body
wish i could hit 9k
Old Jan 29, 2004 | 06:06 PM
Kermit sol's Avatar
ok i changed the gasket on the throddle body and it dident work if any whone else might know what it might be i would great
thank you
wish i could hit 9k
Old Jan 29, 2004 | 06:38 PM
Janky99's Avatar
Honda Guru
make sure all the water and vacuum lines are right
Old Jan 29, 2004 | 06:59 PM
yes and check pvc valve,map sensor and any other vacume lines
Old Jan 29, 2004 | 08:37 PM
Si-R Trickey's Avatar
The most interesting man
Sounds like the TPS sensor or the idel air control valve... maybe?
Old Jan 30, 2004 | 10:19 AM
Punkinterviews's Avatar
Chavez Motorsports
Also make sure the TB gasket isn't upside down, I put mine on upside down once and it did the same thing. Also when applying the gasket put a lite coat of oil on it to prevent it from sticking to the TB or the head incase you have to remove it again.
Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
