LS/VTEC Turbo??????
Old Jan 29, 2004 | 09:14 AM
MadisFastDSM's Avatar
tractionless
Default LS/VTEC Turbo??????
ok im reading all these posts about not going ls/vtec.....(keith) but i was planning on running ls/vtec turbo why shouldnt i...... wouldnt i be able to run more boost w/ the ls bottom end opposed to the gsr because of the lower compression? otherwise im gonna go b16b
Old Jan 29, 2004 | 09:32 AM
tegasaurus's Avatar
vtec where?
Having a lower compression engine doesn't enable you to run more boost in some way, it just takes more boost to make the same power as a "higher" compression engine at a lower boost level. The one limiting factor in an LS engine, in any application, will be the poor flowing characteristics of the head. Better flow is one determing factor in making more power. A b16b, has a cr of 10.8:1, where some would argue would be a little high for a turbo application. There are definitive advantages to each engine (b18b, b18c, b16), which would suit you best, depends on the specific application and your expectations for power output, or range and placement of power band.
Hope that helps.
99 gsr
- B18b -
349 whp - 299 ft/lb
Old Jan 29, 2004 | 12:08 PM
1320's Avatar
I know TK at ZMR has one in his interga and Dave has one he's been driving with no problems
Old Jan 29, 2004 | 07:05 PM
tegasaurus's Avatar
vtec where?
What ?
99 gsr
- B18b -
349 whp - 299 ft/lb
Old Jan 29, 2004 | 07:09 PM
99B16Si's Avatar
theres nothing wrong with ls/vtec as long as its build right and built strong enough for its power output
Old Jan 29, 2004 | 07:10 PM
cochese's Avatar
Chucking up the Dueces
i heard he broke down the other night(not engine related though)what happend?
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Jan 29, 2004 | 07:24 PM
tegasaurus's Avatar
vtec where?
Is everyone talking about different things? No one said there was anything wrong with an ls/vtec setup, if it is done right.
99 gsr
- B18b -
349 whp - 299 ft/lb
Old Jan 29, 2004 | 07:32 PM
99B16Si's Avatar
Default Re: LS/VTEC Turbo??????
i was replying to that not you
Old Jan 29, 2004 | 07:33 PM
99B16Si's Avatar
who did?
Old Jan 29, 2004 | 07:37 PM
cochese's Avatar
tk....................herd he was racing a civic...something gave??dont know what yet.
also i herd sone blew his shit up on his way to oklahoma??
he must be pissed,man i hope he rebuilds!
i talked to kevin,i guess i'm gonna be at the shop sat-or sun morning to get this ___*b*rdata__ tuned?????????
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
